zzman,
I'll try and give you some general info and let the pros give you the detailed info.
Turbo boost pressure is determined by how large or small the tunnel this determines pressure. Also how much exhaust is spinning turbine wheel.
How ever you can adjust or add on a few things to get more boost when you need it. There is a star wheel on top of AFC,turning this I believe toward the pump will increase low rpm boost(it actually allows the turbo to spool up quicker) and give you quicker take off(don't turn it to much or you will get a large cloud of black smoke at take off).
The wastegate can be adjusted to allow for higher boost usually at higher RPM/speed. The wastegate opens a exhaust by-pass door so engine won't have to much boost(I believe to much boost will mess the engine up really bad). But by having wastegate the engine can use a turbo that gives it more boost at low RPM/speed. In the manual the adjustment looks pretty tricky but I'm sure there are several Bombers that will gladly give you instructions.
If you wish you can check the arcives, I know there is a bunch of post on these two adjustments and things that can be added or you can wait until one of the pros come along.
Other things to help turbo reach maximum boost potential is less air intake restriction, larger exhaust housing, less resticted exhaust system or different size turbo and of course getting more fuel to your cylinders.
Bill Thomas
Missouri Mule - 96 Wht 4X4 ST CC,5 spd, 3. 54, 8 ft bed, 1 ft high cheater boards.
99 Freightliner bl/wht FL60 ISB-5. 9 24v,215 hp,520 tq,6 spd, 3. 59 nsr,16 ft box, 19. 5 tires,Wt/gvw 11,000/23000
