How to adjust wastegate for more boost?
Installed the "Special Catcher"
Head studs
JStieger
I have the SPS 66 and want to adjust the wastegate to go from 40 psi boost to 45 psi boost as I am still 1:1 drive:boost at 40 psi. Do I lengthen the actuator rod or shorten it? How many turns?
Before anyone asks, note that I took off the adjustable boost elbow and replaced with a stock elbow.
-Thanks-
Put the adjustable elbow back in use blue lock tight to hold the hex screw after adjust the boost where you want it. That actuator rod is a PIA to adjust.
