Details here: TDR Privileges
I have the banks 14 waste gated housing and i want to get more boost out of it. do i need to turn the shaft so i see more threads or less. it is set at 37psi. i want 45psi
why is it hard just getting to it or do you have to undo something to turn it. I can get to it pretty easily through the fender well. it is going to be a hx 40 compressor.
I think 42 would be the highest I would go but every truck is different. What kind of turbo is it? I have done it to my PDR HX40 and yes it is a pain. You have to remove the C clip that holds the shaft to the lever to turn it. You have to pull the shaft down to the lever because it is under tension.
