Souders said:Thinking about upgrading my injectors on my 24V. How does one ever remove the tube and injector on number six cylinder ? There does not appear to be any room to work in the rear of the engine. Does the motor lifting eye need to be removed for access to this area ?
Input apreciated.
Souders said:Look what I started. Could someone send me a copy of the instructions ?.
rrab1 said:Souders, just put my 1. 5's in last Saturday(3/12/05) and #6 was a pain in the ***** very time consuming, I would recommend a 19 mm crow's foot and a 19mm line wrench, a 3/4 inch line wrench is the same as a 19mm. before you get started. The install is pretty strait forward other than #6 being so tight,but it is worth the time,if you have any questions pm me and I'll send you my phone # and try and answer them for you,Don
