I have a 99 24V truck that I need to check codes on that has a Powermax 3 with remote on it. What do I need to unhook on the PM3 to scan the truck. I assume the pump wire, boost senor feed and a can bus plug to the PM3. If they have a can bus wire like my Edge comp where is it on a 99. I did'nt see it below the fuel filter like on my 01. It's low on power and won't always accelerate when you mash the smoke pedal. I just replaced the lift pump which was dead and now suspect the pump or throttle sensor. I also talked the owner into a fuel pressure guage to go with the boost and pyro he already has. Thanks, Jake
