I recently acquired a GMC Suburban with a 6BT swap done a few years ago. I prefer to use extended-life coolant for various reasons. However, mixing ELC with regular coolant is a big no-no as it can turn into a gelatinous blob and ruin your day. In my powerstroke 7.3 engine, I used Gooch's method, which is well-known in the PSD world and essentially involves removing the thermostat and also removing the block plugs from the engine to drain out all the old coolant before putting new coolant into the system.
Is there an equivalent method for the 6BT? Or, has anyone swapped over to ELC and, if so, what procedure did you use?
Thanks.
Thanks.
