I just bought this truck used a few days ago. It was run pretty hard by the PO. It appears stock except for the straight pipe. What tipped me off was the overhead mpg readings. It reads about 5 mpg high. Now admittedly I just checked after running a half a tank through but I expected it to be much closer. Hoping by some miracle anyway, since it was reading 25 mpg! Actual hand calc was 19.
From reading the forums it seems like the programmers, whether installed or downloaded, seem to mess up the overhead by about that amount. I know the overhead isn't perfect but of the other trucks I have had, those were always within 1-1. 5 mpg. It also seems pretty quick, and lets out a little more smoke, though that could be my imagination.
So, since I haven't found a box installed anywhere, and there are no gauges installed, is there a way to find out if a program has been downloaded? Where should I look to find a box? I checked under the hood and under the dash and don't se anything. I bought it from a dealer so I am not sure if the PO is going to be easy to contact.
