how to disable seat belt buzzer?
ipod videos on the laramie audio
Photos of my new 3500
From R. Patton"s post a few before this one.
Try the tip from Issue 67,page 8 and see if it works on the 2010 truck.
Craig
From the 2010 owners manual;
BeltAlert can be enabled or disabled by your authorized
dealer or by performing the following procedure:
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the ON
or START position. Chrysler Group LLC does not recommend
deactivating the BeltAlert.
1. With all doors closed and the ignition switch in any
position except ON or START, buckle the driver's seat
belt.
2. Turn the ignition switch to the ON position and wait
for the Seat Belt Reminder Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle
and then re-buckle the driver's seat belt at least three
times within 60 seconds, ending with the seat belt
buckled.
NOTE: Watch for the Seat Belt Reminder Light to turn
on while the seat belt retracts and turn off while rebuckling
the seat belt.
4. Turn the ignition switch to the LOCK position. A
single chime will sound to signify that you have successfully
completed the programming.
BeltAlert can be reactivated by repeating this procedure.
NOTE: Although BeltAlert has been deactivated, the
Seat Belt Reminder Light will continue to illuminate
while the driver's seat belt remains unbuckled or
unretracted.
