at the whell bearing it is held by 1 allen bolt. As the lead goes back to the frame, form the tire, it had a connection at/on the plastic fender well cover. (on the inside away from water,
If you look toward the fire wall, and near frame hieght, you will see the little bard sticking through that is the connector.
