How to fix a dead welder?
The shop forum
I just got an arc welder from my neighbor yesterday. When the switch is turned on it blows every breaker down the line, a very bad dead short obviously. Now, I ohm'd out the plug and do not get any continuity from ground to either hot leg with the switch in both off and on. I do get continuity between the two legs with the switch on, which to my understanding is normal.
How do I track down a short in a welder? I don't really know how it works, so it's kind of hard to diagnose.
Matt
Use a multimeter or ohmmeter. It should be a few ohms from each of the two hot legs. No continuity from either hot leg to gnd.
Try that... .
my thoughts about your welder
From what you measured, you don't have a short from either side
of the input power wiring to ground. That is good! However, you
might have a short in the windings of the input transformer. You
measured some amount of resistance so that means that some of
the windings are okay. But, are all the windings ok? The blowing
fuse problem suggests that the resistance of the windings is too
low, which suggests that there is some sort of short in the
windings. I would suggest that you contact the manufacturer
of the welder and ask what the resistance of the transformer
should be. If you have somewhat less resistance than what
they specifiy, then I think you might need a new transformer.
Maybe, that's not too expensive, provided you can buy it and
replace it yourself. Good luck with the repairs.
George
I think George has this one nailed, probably a short on the primary side of the transformer or the internal wiring. Take the cover off and see if there is anything that looks out of order. Traditional AC welders are pretty simple, just a transformer with a switch to select the tap.
