OK, I'll try to describe this problem as clearly as possible.
We have a '98 3500 with 160k.
A problem has developed over the past four months that I've not been able to correct. The problem started when we had the left rear seal replaced.
The problem: If you remove the left rear inner center hub cap you will see eight bolts. THESE ARE NOT THE LUG BOLTS. These bolts secure a plate that keeps the rear fluid in. These bolts continue to come loose. Not just one or two bolts, but all of the bolts.
We have torqued the heck out of the bolts while using loctite and lock washers. All is well for a short time. Then I'll notice gear oil on the left rear tire. I'll remove the center hub cap and sure as shootin', the bolts will be partially backed out.
Any ideas about how to fix this problem?
Thanks,
Bill Cook
Thanks,
Bill Cook
