I'm getting deluged with emails asking about my cheap fuel pressure tester, so it's time to post it on here. This mostly applies to 2001 & up, any older, you may need to modify fittings on the hose to fit your test ports.
It'll work if you have a Schraeder test port on the injection pump, like what comes stock on the 2001's.
I used a cheap $5 air pressure gauge, 0-30psi, with a 1/8NPT stem, mated to a 5' long refrigerant reclamation hose. The hose, which can be purchased in a variety of lengths & fittings at any air conditioning supply house, came with a female Schraeder (Mrs. Schraeder?
) fitting on one end, and a 1/8 NPT male fitting on the other end. I simply used a brass 1/8 NPT coupling to link the gauge to the hose.
You can always drag the stoopid parts counterman outside to show him the fitting on your injection pump, which will give him a general idea of what you're trying to do. Try to resist the temptation to slam his head into the fender, you need his help to get this done.
When done assembling the hose(I recommend teflon tape on all pipe threads, but don't use too much, and don't leave any strands hanging down inside fittings) you can tape the gauge to your windshield, and go for a drive. Not a good idea to leave it hooked up for extended periods.
Give Advanced Diesel Technology www.smokindiesel.com a call, they'll hook ya up with a permanent gauge set up.
Disclaimer: I'm not affiliated with ANY diesel performance shop.
