So I did another re-torque on the head today and finally took it out for the first wide open run since doing the o-rings and twins. I rolled into the throttle and watched the boost climb to 55psi and POW off comes the cold pipe from the 40. Oviously the intake on the 40 is not meant to have a pressure pipe on it hence no barb or raised lip. I had the clamp cranked up as tight as I dared. Anyway, I plan to clean the inake of the turbo and inside of the boot with alcohol and double clamp it. We'll see how that holds but has anyone got any other ideas?
I've seen some guys make a brace back to the turbo and weld it to the cold pipe but I'm not real keen on that quite yet.
Thanks,
Mike
Thanks,
Mike
