I want to keep it stock what should I do to the trans to get the most life out of it?
Do a "pan service", change the filter, fill it up with Amsoil ATF and add a bottle of red LubeGuard from NAPA. Then just drive it an don't worry about it. Its a stout trans.
Depends on the hill. A decent grade yes, rolling hills... Meh. Right foot discipline is definitely a huge factor in longevity.Keep it serviced and take it out of OD as soon as you start climbing a hill. Avoid full throttle launches and refrain from humiliating lesser brands of trucks like ferd and cheby.
BTW, welcome to the TDR.
Scotty
LubeGard (a. k. a. LubeGarbage) is absolutely not needed if the fluid is being changed on schedule. It is NOT an additive. All it is, is a supplement. It does not contain anything special other than what is already in ATF+4.Do a "pan service", change the filter, fill it up with Amsoil ATF and add a bottle of red LubeGuard from NAPA. Then just drive it an don't worry about it. Its a stout trans.
The coveted Allison 1000 behind the DuraMax is a good transmission, but its failure rate is really not all that far behind the 48RE. The demise of both trannys is added power. Rebuilds on the Ally are much more than the 48RE and it is the slowest shifting of all the slushboxes.Really! According to the folks at BD, "20 years of building trucks and Chrysler has never made a trans that lasts unlike the Allison". All I can ad to that is, I need a new trans and it won't be a stock OEM or rebuild. Just my 2.
Agreed!
