Engine/Transmission (1998.5 - 2002) how to measure fp at vp
2nd Gen Non-Engine/Transmission Used truck advise.
Im running the FASS system on my truck and I hooked the fuel line from the FASS to the inlet of the stock fuel filter canister. I wanted to run it this way just in case I had any contaminants in the lines between the FASS and the vp. I currently have my fp gauge feeding from the port on my filter housing.
Now I want to install the line from the FASS direct to the vp but I want to get my fuel pressure readings at the vp.
Is ther a fitting I can use to get my fp readings at the vp
The FASS system elliminates the banjo style fitting and screws into the vp itself so I need a different style fitting to make it work.
