How to Program a 30 second skip with a Comcast DVR
Brick wall backing
JUST be careful and do not OVERIDE a button you use... i. e. numeric 2
To Program your 30-second skip.
Motorola/"Silver" remotes (not sure about Cisco).
1) Press the "Cable" button at the top of the remote to put it into Cable Box control mode.
2) Press and hold the "Setup" button until the "Cable" button blinks twice.
3) Type in the code 994. The "Cable" button will blink twice
4) Press (do not hold) the "Setup" button
5) Type in the code 00173 (for 30 second skip).
6) Press whatever button you want to map the skip function to.
GRAY REMOTE New Motorola RGN200N.
Follow these steps:
1. Press the Aux button
2. Press and hold the Setup button until the Aux button blinks twice
3. Type in code 01376 (the Aux button will blink twice)
4. Press the Aux button again
5. Press and hold the Setup button again until the Aux button blinks twice
6. Type in code 994 (the Aux button will blink twice)
7. Press (but do not hold) the Setup button
8. Type in code 00173
9. Press the Cable button
10. Press whichever button you want to be your 30-second skip button (the Cable button will blink twice). I used the A lock button again.
Now, you'll have have a 30-second skip button while in Cable mode on your remote and can skip commercials and 30-second timeouts during the Final Four games this weekend with the press of a button. One last note: If you previously programmed the Aux button for your receiver or another component, you'll need to reprogram it after setting up the 30-second skip button.
