Engine/Transmission (1998.5 - 2002) how to reach 700hp without NOS/Propane
Engine/Transmission (1998.5 - 2002) 47RE Transmission Weight?
Engine/Transmission (1994 - 1998) Best KDP repair link or thread?
How do I reach 700hp WITHOUT nos or propane...
Current setup
DTT trans
Drag Comp
7x12 240 injectors
water meth dual 625 nozzles (reg washer fluid mix) Snow stage3
62/12 & S400x twins
Just shooting down the road a bit, the twins are being built currently and the truck has been lawn art for a couple months:(
Im thinking cam ,innercooler or maybe a set of springs... . any other ideas?
Thanks
Ian
Fire Ring head and block, balance rotating assembly, port and polish head, Helix 2 cam with springs, intercooler, stack your chip with a Bluechip Redline box connected to the vp44 wire tap and "untap" your comp using it as an Ez, and possibley a Hot Rod vp44 or p7100 conversion. Not sure on the horsepower range but you should be well within 700 rear wheel hp.
I would contact Jetpilot. He has (or had) a really hot 24v. Not sure about the specific's but he'd surely point ya in the right direction!!!
Curtis
you can't Ian... ... . not until i do it first :-laf
here is what Doug told me
Mach 7's
Helix 2 cam
Port the head
Run a TS comp stacked with an Edge EZ.
