How to tell "build date" from VIN?
Block Heaters 101
Engine Wear
The engine has a sticker with a build date on it also. I don't think you can determine much from the vin as far as build date goes. Check for labels on the body like Shadrach says to. The vin will tell you the country and therefore plant assembled.
Take your VIN# to a dealer, he can print you off the build sheet with every little detail of the construction of your truck. It's usually two or three pages long.
While you're at it, you can check the DC service history of your truck.
chazj said:
You might try this website from Cummins if you have the Engine Serial Number.
https://quickserve.cummins.com/qs2/portal/index.html
You have to have a quickserve account to access that.
mind giving out your login info?? :-laf JK
I heard that you can use quickserve without making an account but can only put in 1 or 2 engines
Michael
The vin can give you the yr [ 8th digit ] , [ 10th eng. ] and thats for all cars & trucks , but the vin is mostly dodge orented , the last 4 are where & other dodge stuff , so refure to the eng. # for spesific to eng.
