How to tell which year is which?
water temp sending unit
More Power/Engine upgades?
Hi first-genners, I have a question for you guys. I've been admiring a lot of '89-'93's that I see driving around the greater Seattle area. There's a lot of them up here! I must admit, I don't know much about the '89-'93's, but I want to learn more. Here's my question: Is there a way I can tell which year is which when I see one on the street? Is there a difference in the grilles, badges, etc. that I can look for?
Thanks, Andy
Hi Andy.
The '89's and '90's have a grey grille that
has rectangular openings and it is flat.
The fender baging that has the 150, 250, 350 model designation put the number in a "box" in relatively small lettering.
If it is a 4X4 then the wording POWER RAM will all have the same size letters.
The 89's had a RAM hood ornament.
Also a badge for the Cummins is on the tailgate.
For these years the SE models had a brushed aluminum accent panel that covered just the center 30% of the tailgate.
The 91's-93's have a smooth chrome grille with four openings and a black plastic insert in each operning.
Fender badging for the 150, 250, 350 designation is very similar to the new trucks in lettering style.
If a 4X4 the word "POWER" in "POWER RAM" will have smaller letters than the word "RAM".
There is no Cummins badge on the tailgate.
If an LE (replaced SE desigation) model the tailgate will have a large brushed panel with the word "DODGE" in black letters stamped in it. It covers more than 75% of the tailgate sheet metal.
'93 W350 Club Cab, Bright White, 5 sp. , 130K, Factory Options: Bucket seats replaced with factory split bench, LE, 4. 10, Limited Slip, 7600 lb. rear springs, tachometer, front stabilizer bar. Mods: Banks stinger plus, Linex bedliner, 25,000 lb gooseneck ball, 10,000 lb receiver, Tekonsha brake controller, POWER WAGON injectors-WAY faster than stock!.
Another way that I use to tell on older cars their years was by looking at their tail lights. They usually have a '92' or whatever year it is stamped on it as part of the part number. Not sure if that holds true for the trucks. I haven't even looked at mine to see... . LOL. Too busy driving it. .
Scott
92 Ram, club cab, LE package, 4x4, 3. 54 gears, auto, 285x75x16 Cooper Discovery A/T, running boards, sunvisor, bug deflector, Tonneau cover, Full cap, DynoMax muffler, 5" Chrome Tip, 16 cm Turbo, Boost Gauge
Mark 93
Doesn't the 93 model have honeycomb in the grill??? I know that the 91,92 have the slotted vents in the grill.
Not sure.....
In Canada, the '90's have daytime running lights. Mine doesn't. #ad
Jason
How about a Sig??? Man am I asleep. .
Jason's Lil' Mack - 89 D250LE 2WD 5 Spd 3. 54 Reg Cab. K&N,"tweaked pump", BD Hi perf Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. 23 Lbs boost.
E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs.
232,500 miles (372,000 Kms) 7700 Hrs.
Hi Jason.
My '93 has the slotted vents. When I looked into purchasing those vents the dealer only showed those kind.
If you see one with honeycombs it may be that someone customized the grille.
When did Canada start requiring the lights?
Have a good weekend!
