How to test MAP sensor?
Chrome bubbling on grill
Fuel Pressure Gauge "buzzing"
It's almost impossible if not impossible to test this across the range. I don't have a service manual with me but believe that the voltage is around 4. 5 at sea level and goes to 2. 5 at 10,000 feet. I may be backwards in the voltages but my point it that you can only check it across the range with a hyperbaric (sp?) chamber to simulate air pressure at altitude. The only fault you would get is a code set to indicate voltage too high or voltage too low using a scan tool. One indicates the sensor is open and the other indicates it has shorted. The voltages at high/low altitude are given in the service manual if anyone has one handy.
There are some threads from a year ago that discuss the changes with the '01 map sensors. The outputs are different from pre-'01 units.
Unscrew sensor from manifold and connect to a regulated air supply. There are three electrical connections on the sensor; 5 volt supply, ground and 0-5 volt output signal. You can use a standalone power supply. I just inserted a pickup wire into the output connector and plugged back into the truck. The results are below and were verified by CannonBall.
You may set a code when you switch the ignition on to identify which pins do what. You will set an overboost code if you go much over 2. 5 volts
lbs volts
0 1. 068
5 1. 402
10 1. 732
15 2. 061
20 2. 391
25 2. 720
30 3. 050
