Ok....here we go (long)
Thanks Wes... .
Edge Comp installed ~last of Feb. Replaced EZ.
About three weeks ago, over a period of about a week, cruising at ~30-35 mph. under light throttle..... gave it more throttle and truck just didn't respond for maybe 10 seconds. Didn't stumble... . just didn't respond... . a dead spot. Didn't happen again for a few days... . maybe 4 times total over a period of a week... . never repeated in predictable sequence. I worried/wondered, but didn't take any action.
Last Thursday, 4-10, while starting from a dead stop, the truck just wouldn't pick up speed... . I could barely get up to 10 mph. No stumbling, bucking,... just wouldn't accelerate. After maybe 20 seconds it "caught" and I was back to normal. Freeked out and checked for codes. NOTE: Check Engine Light was NOT on, and have not gotten one through all the rest of the stuff below.
Codes: 1693 (Turbo charge Control Circuit Malfunction)
P-ECU ( Can't identify, but have been told it's not concerning)
0216 (Fuel Injection Pump Timing Failure/Injection Timing Control Circuit Malfunction)
Obviously, the 0216 worries me. Have a Fuel Pressure guage, post filter, and the numbers are strong. Boost and EGT's like always. But, since that date, I have driven over 650 miles and the truck has performed flawlessly, but I can't get rid of the codes.
Tried so far:
4-11: Private mechanic read and cleared codes with scanner. Comp still hooked up and running on level 3 as it was all of the prior time. Drove 200 miles and I did a code check. They were all back, plus I got a 0522 (Engine Oil Pressure Sensor/Switch Circuit Low Voltage) Oil level and pressure are fine. Truck running fine.
Also, we scanned the TPS, checked the MAP sensor plug for fit and dilectric grease, checked the voltage of the red pump wire at the injection pump. All fine.
4-14: Mechanic cleared codes again with scanner, but when they were cleared, the only ones showing at that time were: P-ECU and P0216. ( I don't know what happened to the 1693 and 0522 that were there before)
Turned the comp. off in the cab and drove 30 miles home... . checked codes and got a P-ECU, only.
4-15: Again, with comp. off in cab, drove another 63 miles, checked for codes and they're back... . 1693/P-ECU/P-0216
4-16: Drove another 160 miles and same codes present. Disconnected the negative battery cables for two hours. Checked for codes... P-ECU and P0216 came up. Drove 25 miles and checked again... . the l693 was back with the other two.
So, it appears I can't, by process of elimination, rule out the comp unless I disconnect the whole unit, and I've just been wasting my time just turning it off in the cab. I also think it's strange I've never gotten a Check Engine Light, especially with a code involving the injection pump.
Any other ideas/suggestions appreciated. Sorry for the book.
Joe
