Best ratio is 1:1, but anthing below 3:1 will work, it's not just as good. I might be misunderstanding you but you don't use the CAL to tune the antenna. You make the adjustment on the antenna then use the meter to see the ratio.
As in the previous post check channel 1 & 40. Since I am usually on channel 17 or 19 I tune the antenna for these and the lower and higher channels "fall into place. "
If you need a full set of instructions, I can fax them to you, email me your fax number. The instructions are for a Cal Comm meter. They use "FWD" for calibration and "REF" to see the ratio.
