Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canConvertThreadToRmsItem is not callable on the given object (SV\SearchImprovements\XF\Entity\ThreadCollab) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsReview is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsQuestion is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsFaq is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsEvent is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsLocation is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsCheckIn is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
How/Where To Connect Wastegate on HY35 to HX35 Upgrade?
Front Plastic air dam
Exhaust.....YES, AGAIN!!!
RADdodge
I'm upgrading my turbo from a HY35 to a HX35 and was not quite sure how the wastegate is connected. I have a new elbow. Do I drill, tap and install a push-on fitting in the new elbow and run some 1/4" hose (?) from there to the wastegate fitting? Any helpful suggestions would be gladly received! Thanks in advance.
Originally posted by Bruce Radford
I'm upgrading my turbo from a HY35 to a HX35 and was not quite sure how the wastegate is connected. Any helpful suggestions would be gladly received! Thanks in advance.
Bruce, talk to Piers in BC. I've upgraded to a 12cms housing HX35 unit with Piers assistance :) . He'll steer you right!!
