Howling noise in front end / tires.
Front suspension instability observation
Air vent replacement question
Has anyone had a noise like they are running big off road tires when they swerve or go around a curve? I thought it was the tires ( Stock Michelin tire's) so I had them rotated and balanced and they checked out good. The noise seems to be getting louder and you can only hear it when you swerve the truck or going around a curve at high speeds. Any ideas?
Had the same problem on my 01. It was the bearing assembly. I thought it was one side but turned out to be the other side.
