Engine/Transmission (1998.5 - 2002) HP/Torque guesstamation?
Engine/Transmission (1994 - 1998) OD & TC Controller
Engine/Transmission (1994 - 1998) fuel plate and stock clutch?
If you look at my sig, this is what I have currently. I just ordered a set of stage 1 jammers and was wondering approximately how much power will I have after installing these.
depending on how you drive the stock clutch should be ok. I am running a comp and jammer 2's and have yet to make my clutch slip even at full throttle. If you tow heavy just make sure that your foot is all the way off the clutch before you touch the throttle and I dont think you will have a problem.
My brother ran a edge comp & had no clutch problems. Added a set of rv275 injectors... still no problem. Sold the comp & bought a smarty= slips on cold days.
Mmmm ... Maybe I should have gone with the 2's. Do you have any EGT issues?
with the comp on the lowest settings egt's aren't a problem as long as your foot doesnt stay on the floor, by the time they start getting hot speeds are in the triple digits, for towing in the 10-14,000lb range they work great for me.
Thanks for the great responses. I think I'm on the right track with the Mods that I am doing. That's what I like about the TDR, all of this great information and expriences shared by all the members!
