HP & Torque numbers - What to expect?
Grease Rear Axle Bearings?
Truck pulling pics
I am planning on adding Bully Dog Stage III injectors later this summer. With the EZ box and injectors installed can anyone give me a ballpark figure on HP and torque? Is there anybody that is in my geographical area that does clutch installs? TIA
John
John,
With the experience on my truck, I would say that you will be somewhere between 330 and 350 in rear wheel HP with Bully Dog III's and an EZ.
350 HP / 700 ft lbs sounds right. Do you have some plans to upgrade your clutch as it probably won't hold that much torque? South Bend has had some good reviews lately by other members with one too many pedals :D
Thanks for the info and yes I am already planning on a clutch. I talked to Peter at South Bend Clutch and got the clutch and price all settled. That shop looks like it might be a good place to go. I'll check it out. Thanks again.
John
365. 8, let's round it off to an even 366 :D at the rear wheels with what you see below, no torque numbers as the dyno was not set up to provide same. These numbers are pre-TST box.
Scott W.
