Engine/Transmission (1994 - 1998) HP & TQ with 330 Marines and 180 Pump
I got the 330 marine injectors installed. The truck idles smoother with less startup smoke. My boost jumped 10psi from the WH1C to 30psi. Next comes the hybrid Super 40/35 turbo.
Does anyone have any dyno numbers for a 330 marine, 180 pump at 15. 5 deg, #6 plate, 4" exhaust or similar combo?
Thanks.
this is probably not useful to you but my truck with no mods but a bhaf 16*timing, ats exhaust manifold and 330s did 248 hp with a dieing lift pump, it got a good bit spunkyer when i installed a new pump, it was a free dyno event so they weren't giving out torque# but i come up with 520 using math 248 hp and figuring that the hp peak hits at around the stock rpm rating
