Engine/Transmission (1998.5 - 2002) hp/trq #'s
I recently had my truck on the dyno, and was told it went for 309hp. and 909ft/lbs. Is it normal to have the hp and trq so far apart.
Somethin's up. With a 309 you should be in the 710 range numericly speaking.
As a Quicky the 2. 3 multiplier is the quick way. The long way is well ... long.
What else mods wise do you have?
Ddm
Seems a little high on the torque for the horsepower from what I've experianced at dyno days events.
When my truck had an Edge EZ w/RV275's I was dyno'd at 301HP/690HP.
In my current config 402HP/885 range.
What mods do you have? Manual transmission?
What brand Dyno?
I have a 99' 5speep, edge drag comp, 4" exhaust, vp from schied, afe filter, holly blue pusher pump, mitchel dual disk.
Before puting my new vp on I did 379hp,793ft/lbs both were tested from schied.
Sorry I couldn't reply sooner.
