HPCR Injector Changes throughout the years
2003 Transfer Case Help Needed.....it blew up
Po243 sob pos
Some have asked about changes throughout the years.
1. With the model year 2003-2004 injectors there were problems with the high pressure sealing ring. Bosch solved that problem by changing its design.
2. Another problem was wear on the nozzle needle guidance and tip. Bosch introduced a wear coating on the needle. Bosch improved the particle robustness with that coating on the needle and with a coating on the valve seat.
3. There was a design change in the contact area from the valve piston to the nozzle needle. They eliminated the bigger intermediate pin and changed it to the smaller pin / puck design. That reduced side forces on the nozzle needle which also reduced the wear on the guidance and made the injector more stable at low rail pressures when the forces for opening and closing are low.
There have been no body changes beside the outer coating.
The 6.7l Cummins injector is a different injector generation, so its internals are different. Since 2007 when it came to the Cummins, there have been only very small optimizations. No big changes.
Hope this is a help!
Thank you!
Good morning Alan!
The coating on the valve seat and the needle was introduced during 2005 and the Puck design change was in 2006. Bosch changed injector part numbers with these updates.
Updates for the Bosch remans? They get the nozzle with the coating and a new high pressure sealing ring. Does Bosch put a new valve piece into it if the hard chrome coating is missing and it looks good? Not likely! They will definitely not make a change to the puck design.
Thank you!
