FUEL CONTROL ACTUATOR
DESCRIPTION
The Fuel Control Actuator solenoid valve is located on the back of the front cover of the high-pressure pump. The solenoid is pulse-width modulated by the ECM and meters the amount of fuel that flows into the high-pressure elements inside the high-pressure pump.
The solenoid is inactive during the first 30 seconds after IGNition switch is initially keyed to ON position to allow maximum fuel pressure to the fuel rail during cranking and start up. ECM assumes FCA valve control when CPS signal and rail pressure are within acceptable limits
OPERATION
The Fuel Control Actuator solenoid valve is a pulse-width modulated valve that controls the amount of fuel sent or delayed to the high-pressure pump elements inside the high-pressure pump. The ECM determines the fuel pressure set point based on engine sensor and rail-pressure inputs. If the actual fuel-rail pressure is too low, the ECM commands the solenoid to allow more fuel to flow to the high-pressure pump. This minimizes the difference between the actual fuel-rail pressure reading and the set point. The ECM will also operate the solenoid to delay fuel, reducing flow-rate, if the fuel-rail pressure becomes too high.
The FCA valve is commanded open by the ECM to allow the high-pressure pump to build maximum pressure
(1600bar, 23,206psi).
Thus, rail fuel-pressure can be increased or decreased independent of engine speed
High Pressure Pumping Plungers
The FQS valve supplies three high pressure pumping chambers. The pumping chambers have one-way
inlet valves that allow fuel to flow into the chambers. The valves then close as the fuel is compressed,
causing the high pressure fuel to overcome a spring-loaded ball-and-seat outlet valve.
All three pumping chambers are tied together in one circuit internal to the pump and provide high pressure fuel
between 300bar (4351psi) and 1600bar (23,206psi) through a steel line to the fuel rail.
The pump is driven at 1:1 engine speed and is not responsible for injection timing.
Pump function is to provide fuel at high-pressure, while the ECM controls injection pressure and timing.
FUEL RAIL
DESCRIPTION
The fuel rail is mounted to the cylinder-head cover\intake manifold. The rail distributes regulated high-pressure fuel equally to the fuel injectors.
A pressure sensor is screwed into the rail so ECM can read and regulate system pressure.
A pressure relief valve is screwed into the rear of the fuel rail to allow overflow return to the fuel tank.
OPERATION
The fuel rail stores the fuel for the injectors at high pressure. At the same time, the pressure oscillations which are
generated due to the high-pressure pump delivery and the injection of fuel are dampened by rail volume.
The fuel rail is common to all cylinders, hence it’s name "common rail". Even when large quantities of fuel are
extracted, the fuel rail maintains a constant inner pressure. This ensures that injection pressure remains constant
from the instant the injector opens to the end of the injection event.
PRESSURE LIMITING VALVE
DESCRIPTION
The fuel pressure limiting valve is located on the top of the fuel rail.
OPERATION
Fuel pressure at the fuel rail is monitored by the fuel rail pressure sensor. If fuel pressure becomes excessive, the
pressure limiting valve opens and vents excess pressure into the fuel drain circuit.
FUEL LINES
DESCRIPTION
LOW-PRESSURE FUEL LINES
All fuel lines up to the fuel injection pump are considered low-pressure. This includes the fuel lines from the fuel
tank module to the inlet of the high-pressure fuel injection pump. The fuel-return lines and the fuel-drain lines are also considered low-pressure lines.
High-pressure lines are used between the fuel injection pump and the fuel injectors
HIGH PRESSURE FUEL LINES
High-pressure fuel lines are used between the high pressure fuel injection pump and the fuel rail, and between
the fuel rail and fuel injectors
All other fuel lines are considered low-pressure lines.
OPERATION - HIGH PRESSURE FUEL LINES
High-pressure fuel lines deliver fuel under extremely high pressure - between 300-1600 bar (4351-23206 psi) - from the high-pressure pump to the rail to the fuel injectors. The lines expand and contract from the high-pressure fuel pulses generated during the injection process, which can delay the injection event - ECM compensates for that based on component specs
All high-pressure fuel lines between the rail and the injectors are of the same length and inside diameter to ensure equal-duration injection events, cylinder to cylinder.
Correct high-pressure fuel line usage and installation is critical to smooth engine operation.
FUEL MANAGER\FILTER
FUEL FILTER / WATER SEPARATOR
DESCRIPTION
The fuel filter/water separator assembly is located on the left rear side of the engine. It incorporates
the fuel temperature sensor, fuel heater and a Water-In-Fuel (WIF) sensor.
Only the fuel filter cannister and the WIF sensor are serviced separately. The top-loaded fuel filter has a 3-micron element and the cap
tightens clockwise to the housing.
OPERATION
The fuel filter/water separator protects the high pressure fuel injection pump by removing water and contaminants
from the fuel with a 3-micron filter element. The construction of the filter/separator allows fuel to pass through it,
but helps prevent moisture (water) from doing so. Moisture collects at the bottom of the cannister for draining.
A Water-In-Fuel (WIF) sensor is attached to the fuel filter cannister and is serviced separately.
The fuel heater and fuel temperature sensor are in a thermoplastic module inside the fuel manager head - it is not serviced separately from the head.
WATER IN FUEL SENSOR
DESCRIPTION
The WIF sensor is attached to the bottom of the fuel filter/water separator cannister. The sensor also has a drain channel and provision for adapting a drain hose.
OPERATION
The sensor varies an input to the ECM, allowing it to sense water in the fuel filter/water separator.
As the water content in the filter/separator increases, the resistance across the WIF sensor decreases. This
decrease in resistance is measured by the ECM and compared to a calibrated standard value. If the resistance
drops to a value between 30 and 40 kohms, the ECM will activate the Water-In-Fuel warning lamp. This all occurs when the IGNition key is initially switched to ON position
FUEL HEATER
DESCRIPTION
The fuel heater is used to prevent diesel fuel from waxing and plugging the fuel filter during cold weather operation.
The fuel heater is located in the fuel heater module, next to the fuel temperature sensor - the module is internal to the fuel manager head.
On temperature is 7°C (45° F), off temperature is 29°C (85° F).
