I replaced the pump with a HRVP, dropping the key down into the motor in the process, so I took the front cover off, got the key in, installed correctly, all put back together, all electrical connections in, good fuel pressure, bled at the pump and then injectors, fuel coming out of injectors where I crack them, occasional fire, but no start, and I have cranked a lot. Tons of white smoke coming out the tailpipe. What could be wrong? Keep cranking? Thanks
