Engine/Transmission (1998.5 - 2002) Ht2b Questions
I AM GOING TO BE GETTING AN HT2B HERE IN ABOUT A WEEK. MY QUESTION IS WHAT TYPE OF EXHAUST HOUSEING SHOULD I GET.
I AM GOING TO BE RUNNING THE EDGE COMP WITH 150HP INJECTORS.
I AM ALSO GOING TO BE TOWING ABOUT 15k
I would say the larger "14cm" housing, assuming you are getting a 62/??. I would think you could get away with the smaller "12cm" housing depending on what type of terrain you are planning on pulling.
That is similar to the 99 in my sig. It has a 62/12 on it. Works good.
DO you plan on towing and using the power of the edge comp?? The 01 truck in my signature I have towed 10K with and had no egt issues, but that was with the comp on level1. I didn't turn it up past that since I feel it is hard on the drive train to pull that kind of weight around with those kind of HP.
