Engine/Transmission (1998.5 - 2002) HTB2, How is it compared to twins for towing?
Engine/Transmission (1998.5 - 2002) fuel pressure gauge...
Are any of you guys using the HTB2 for towing? Hows it working? I've got an 01' ETH with a drag comp and 150hp injectors. I would like to try this turbo. How is it compared to a twin setup iwth HX-35 and HT3B?
It won't work with 150hp injectors. I'm running Mach 3s with the HTB2 and a drag comp and tow with the drag comp on 3X3 with no problems. The Mach 3s are only 125 to 130hp. Any more fuel and I would be running warm. I'm also below 2000 feet on altitude at all times.
It's a nice single for towing but should in no way be compared to a set of towing twins in the 4-500 hp range.
-Scott
