I haven't seen anyone post any towing results using the HTB2 turbo so I am posting mine. I just got back from my trip while towing a 5000 lbs boat over flat and rolling terrain. It's not a heavy load but enough weight to tell its back there. At 75 mph on level ground EGT's were 825 at 16psi. On hills I was seeing 900-1000 degrees at 30psi. EGT's never exceeded 1000 but I didn't push it past 75 mph and none of the hills were very long (Houston to Austin via I10 and 71). The box was left on 5x5 for the whole trip. Air temp was in the 90's and humidity was high.
I few side thing I would like to note. The transmission never down shifted and the TQ never unlocked. transmission temps never left the 150 mark and water temp never exceeded 195. You also get quite a few looks when you spin the tires at a stoplight while towing a large boat.
