Well, after talking with many people here on the forum and the guys at HTT, I decided to try the 12cm housing. I was bothered with the lag the turbo had when I first put it on and wanted to gain some of that low end back. Some suggested bigger and better injectors to help the light up the turbo quicker. This is still an option and will happen some day(sooner thn later) but for now I wanted to maximize what I have and try the 12cm to answer the question myslef. I just put it on last night so I only have a few miles on it. So far it seems to spool quikcer, which I expected, and seems to smoke a little less. With the Comp on 2x2 I hit 1077* EGT and 33. 6psi boost. The highest I had hit for boost before with the 14cm on 5x5 was 35. 5psi. I checked over things at lunch and will crank it up a little more this afternoon to see what it does. So far so happy... we'll see how the gauges look on 5x5 this afternoon. I kind of use 5x5 as my number to know what my max can be... and I have it recored already for the 14cm. I really noticed the probelm a few weeks ago at elevation. Lag was very noticeable, EGT's were high and boost was low. I will be at the same location(7000ft) this weekend to see how it compares. I will hang onto the 14cm until I decide which I like. HTT also said should I like the 12cm and add more fule later, I could trade into the larger compressor of the HTB2. I will report back with more results this afternoon.
