HTBG vs. HE351CW....... turbo gurus??
Idelup a manual Any way around clutch switch
Mild power boost
I'm struggling to find out what my stock HE351 turbo is comprised of and capable of. I understand it's a 62mm/9cm turbo. before i figured that out, i was looking at the HTBG 57mm/12cm as a good match to the upgrades i wish to get. even if i get ALL the advertised horse power for the Flux1s and EZ, i should still be well below 450hp... . probably even a bit below 425hp at the flywheel. i intend to use the EZ mostly on setting 1 which would put me around 400hp.
so what would be the advantages and disadvantages of either of these turbos considering the mods mentioned??
not familiar with the HE351, but the HTBG is a good mild turbo. I get 45psi and quick spool with my set up but can't push for long over 450 HP as the EGTs get too high. HTT lists the HTBG for 425 hp and thats about right.
