HTML code for Signature
Email virus - Administrator please respond
Private messages/private emails
I am looking to add to my signature file the code to send users to the web page with pictures on it. As you can see i have what i thought was the code below in my signature. Do you know of any mistakes or the way to post it.
thanks
Posting Web Address
The new software does this for you all you need to do is put the full web address in. You can even do this by copying from the adress box and pasteing into place. Another way to do this is to use url, /url, each in square brackets, either side of you address with no spaces. If you have done this correctly, the link will blue.
Example: http://balsabeavers.ca
Hope this helps,
Neil:D
CAM
I've noticed that HTML tags do not work well in replies and signatures. You could try vB Code in your signature.
I had to change my anchor tag from HTML to vB code in order to make it post properly. I quess if we can learn HML tags we can certainly learn some vB code?
VB Code
Just an FYI... .
The use of VB code prevents nasty scripts and objects from being embedded in the postings. :)
Ken
TDR Admin
