Engine/Transmission (1994 - 1998) HTS dyno results
Engine/Transmission (1998.5 - 2002) Pusher Pump Kits
2nd Gen Non-Engine/Transmission Wheel backspacing?
Hey guys thanks for the replies about my #5 plate questions now tell you how the dyno went for me I had to run in overdrive though because I kept kicking out of the converter in no od so here is the numbers 305. 5hp and 845. 7ftlbs and if you look in the numbers individually on the print out when I ran my high marks were 308. 282hp and 887. 753ftlbs so I'm happy with hp hope for about 330 but torque is awesome I had figured I only get maybe 700 so not to bad for only having #5 plate slide forward and afe stage 1 air cleaner. and 257,000 Miles on truck. Now what to add next any suggestion?
if any of you guys have any suggetions of what to do next to truck let me know if I get the ok from some of the other guys that were there I will post there number. but they were waiting to get higher number first not like 430 to 500 hp and 800 to 1297 ftbls is bad but there is guys with higher number out there
