*** HTT 4" down pipe *****
Dodge trk=1, Deer=0
A low whine or moan
IS THIS THE ONE THAT DOES NOT FIT A FIRST GEN WORTH A DARN????
thanks
don
ps - dp for a s300 turbo...
i remember hearing some dont fit
is the one from htt one of them?
They might, but I doubt it would be 'bolt-up'. Most likely it will just be a 'ball park' piece. Would probly require additional cut/welding and modifications to fit your system.
I bought my 4" DP from Rip, you have to weld whichever flange you want on it. I also got the 4" v-clamp flange that's slides inside the DP, should work out great. I don't have it installed yet.
couldnt find rip
pdr cuts up a 2nd gen pipe and says it will fit when they are done
225 w/o clamp
thats almost 300 shipped 2nd day air
dang...
i just got back from custom tubing place near my house - they do not have tooling for 4". theres stops at 3. 5". does anyone know of a place where they can make us some v-bends or even just some 90's with a really tight radius????????????
i have built several ex sys and you could roll a ball thru all of them when i was finished. purge w argon before weld, whole nine yards. that is how i like to do it. i think having the flow run into a wall apon exiting the charger is probably not the best thing for performance...
what do you guys think?
would you be interested in a group buy if we can find someone to bend the tube?
how many s300 equip 1st gens are out there anyways?
don
Don, Buy Rip's downpipe or even Stans and cut the flange off and modify for your use. I wouldn't touch a Second Gen DP, if you ever see the two side by side you'll know what I mean. Whatever you do make sure it is Mandrel bends.
