HTT Intercooler install
urathane carrier bearing
Rear Brake Pads
Installed a new High tech turbo intercooler yesterday. I thought about replacing the factory CAC for a while but did not because of the cost of a good replacement. The factory unit with the plastic end tanks finally started to leak bad so I had a good excuse to upgrade. Looked at alot of coolers online, hard to tell who's is the best vs. cost etc. Decided on HTT, bought it on ebay $1210 with free delivery. New unit looks awesome, all aluminum and all seams and attatchment points are tig welded. The problem with website pictures and advertising is you just can't tell until you recieve the product, some products have alot of info some don't. If any manufacturers are out there, better pictures and stats would help your product sell over the competition. Install took 3 hours, pretty straight foward. If you do this install trim the bumper bolts before you install the cooler. Brackets had to be moved on the AC condenser (very easy). I had to make spacers for the A/C condenser as it was resting on the cooler. EGT's are lower +-500 70 mph cruise flat ground vs. +600 before. Turbo spools faster and cools down ALOT faster. No I don't work for HTT or sell them. Great product. The instructions are minimal but if you can take the old one out you can install one. HTT cooler weighs 70lbs vs 15 for the stock one. HIGH quality, IView attachment 72541
View attachment 72543 would not hesitate to buy again2005 2500 4x4 NV5600 QC LB white. 3. 73 Banks 6 gun speedloader, pyro, boost and oil temp guages. 5" tb exaust. Aero muffler. HTT cac, FS bypass filter. Afe pg7. Cool blue hose. Air box mod. Ams oiled. 2" leveling kit. linex, Nitto 295 75 17. Pro Comp wheels. B&W hitch. Hellwig 2500 helper springs.
2006 Thor Jazz FW 34' 10,000+-
Dang, I know it's bigger and aluminum, but 70 pounds? Am I reading that correctly? Wow. I'm reminded of my younger days throwing around feed sacks and hay while working at the feed store...
70 lbs included the cardboard box (which was large) but yeah it is heavy. It was a bear lifting it in, would have been easier if I had someone to help. Stil have not tower my FW yet, I will post before and afters when I do.
