2nd Gen Non-Engine/Transmission Hub bearing bolts loose!!
Engine/Transmission (1998.5 - 2002) Drive shaft bolt size
Engine/Transmission (1998.5 - 2002) sluggish on take off
Just got new tires on my truck last week and the front end just dint feel right. I crawled under to find my (4) hub bearing bolts loose on both sides. very loose on the right. I could of swore I properly torqued them last fall when I replaced u-joints. I did anti seeze them as well around the bearing assm should I not have??? I did tighten things back up and going to monitor them closely.
General rule of thumb... ... ... avoid anti-seize when torque # is important. Torque specs are for a lightly oiled thread in most cases
