2Low is easily achieved on the 2nd gen trucks with a normally open solenoid valve and a toggle switch in the cab. I teed off the vacuum line at the fire wall where it drops down above the transmission and ran vacuum line over to the passenger side corner of the engine compartment where I mounted the N.O. solenoid, came out the other side of the valve back along the firewall and down the top side of the trans to the switch on the TC as it is normally ran. The toggle switch is a tad delayed, if I dont give it about 5-10 seconds before grabbing the low side sometimes I will get 4 low rather than 2 low. Aside from that it works great and I've used it many times. I spent some money on a decent solenoid valve (around $35-$40) but I wanted a continuous duty cycle valve in case I need 2 low for an extended time or I forget to flip the toggle switch off when I go back to the high side.
