While serviceable bearings, provided they actually get serviced occasionally, are infinitely more reliable and durable than unit hub non-serviceable bearings, it is still possible to get a bad one or have something go wrong. In the unlikely event that ever happened, you can pretty much count on replacing both the hub and spindle. Catastrophic u-joint failure or ball joint or lockout hub failure can also destroy those parts. Again, highly unlikely.
Besides the advantage the dual piston calipers might offer, and I'm not concerned about the master cylinder capacity or even swapping master cylinders if necessary (think about the pricey dual-piston conversions out there for which this is not an issue), I also want the extra strength of 5 spindle studs vs. 4 bolts. The good old chevy/dodge kingpin d60's used 6 spindle studs.
Another way to do this yourself, but you give up the calipers and 5-stud pattern, is to use the ford spindles and hubs and have the spindles redrilled to match the dodge 4 bolt knuckle. There may be some slight machining necessary to match the spindle-to-knuckle bore, I'm not sure, but there was at least one guy offering such kits at much lower price than the dynatrac or spin tec kits. You would then use ford rotors and your stock dodge calipers. In either case, it is advisable to have the ford hubs machined slightly to make their outer diameter match the smaller dodge/chevy specs for no other reason than ensuring that stock dodge wheels will fit.
As with any other kit, you then need to order readily-available inner and outer axle shafts. Axle shafts will always be available in custom sizes if you cannot find existing stock shafts the correct length and spline. Just contact Yukon or Moser or similar. Using the ford knuckles-on-out approach means using ford outer shafts and the custom made-to-fit-CAD-axle-dodges inners that different companies offer.
I do not know for sure what outer shafts you need with the ford spindle-and-hub only approach with dodge knuckles. I do know for sure another member here (probably more) used that guy's kit, so he would know what is needed for sure and where to get them. We were pm'ing back and forth about the similarities and differences in our approaches to solving the stock problem. He liked the kit, btw. He ended up with a slightly wider wheelbase, but I think all of these kits/conversions do that. It wasn't noticeable or any problem all.
At that time, his method of using the other guy's modified-ford hub and spindle kit saved him at least 1/3 of the price of a dynatrac setup and spyntec had yet to even offer a kit. By bargain shopping (slowly!) I figure to do the whole enchilada with 35-spline stuff all the way for somewhat less than he paid, or about half what dynatrac or spyntec wants. I could have saved a bunch staying with 30-spline stuff, but that defeats the purpose, imo. The Premium Warn Stainless Steel 35-spline lockouts alone cannot be found for much under $250 these days. But the axle shafts aren't much, if any, different in price for 30 or 35 spline and I already have a couple of spare 35-spline chevy D60 carriers.
Ball joints remain a weakness and Dynatrac introduced some new rebuildable "super" balljoints over a year ago to fit our trucks. But they were extremely expensive (4 times as much as Moogs) and had no track record so I did not want to be a guinea pig for that much money. I have no idea if they still offer them or how they have worked out for anyone who really stresses balljoints like I do with both the weight of the cummins and the weight of a snowplow. That would have been an excellent test for them and I offered to do so, but dynatrac didn't seem interested in a real world test like that, so I went with tried and true Moogs.
