OK this is my first post. so here goes.
My 1999 ctd w/ddt trany,1. 5 edm injector,bhaf,edje comp w/wire not taped has a large and i mean huge oil leak. after i drive about 10 miles the hole bottom of my truck is covered in oil :--) . i have cleaned cleaned cleaned and then degreesed it some more and finley tracked it down. it is comming from the drivers side and from under the ecm,the heat pad for the injector pump is also soaked.
this is what i have done
1)re-sealed vacume pump
2)re-sealed front gear case & fixed kdp
3)new valve cover gasket
please help
Alright more info
I do have a extended vent but it is clear no obstructions.
i an afraid it may be a head gasket becouse where the head and block meets it is wet from the back driver side to the front almost to the gear case. seems there is more oil where the ecm is. in less than 5 miles the hole d/s block was covered in oil.
also the back of the gear case cam. pos. sensor,front of vp and vacum pumps are dry.
please help
Alright more info
