Hughes converter & TFOD-Diesel shift kit in
Star wheel, Tach, and Pyromeeter ?
more funky speedo symptoms
Just picked up the truck from a friend's shop after having the trans "freshened-up" (new seals, clutches, pump bushing) and a Hughes converter installed. Also had them put in TransGo's TFOD-Diesel shift kit and swap in a later flex plate while it was out. With the exception of a couple clutches that were burned very slightly, everything looked really good inside. As far as we can tell, the aluminum flakes I found in the pan were coming from the stock converter, and the brass/copper stuff I found wasn't excessive. :)
With the tighter converter and shift kit the truck drives much better. I can actually feel it shift, and there is a noticable drop in RPM (no tach:(). It also takes less throttle to get the truck moving. Boost seems to come up a little quicker, too, and maybe even a little higher max PSI... but I couldn't get on it too hard because the roads are a little slick. ;)
I'm anxious to get some more miles on it, and also to see how it does with the camper on or the Jeep hooked to the back - I'm betting there will be a big improvement over stock. ;) I'm leaving on a 3500-mile trip in about two weeks, so I'll have plenty of time to evaluate things. :D
I also had a Transgo TFOD shift kit put in the 518 that I'm using in the project in my sig below. I also replaced the flexpalte "while everything else was apart" and replaced the Torque Converter with a new Mojave Green unit:
http://www.mojave-green.com/inc/pdetail?v=1&pid=379
How well is it working out for me? Can't tell ya, as I don't have it on the road yet. And I was not able to drive the truck that this engine and transmission came out of so I also don't know if it will be an improvement or not. I DO know that the shop that put the kit in said the trans was in EXCELLENT condition inside. I was relieved to hear that.
Don
