I had a different brand propane setup on my '91 - so don't like to be too specific on the Bully Dog setup - but the setup I had used a flow solenoid that was designed to shut flow off completely when power was removed - but like anything else, they can fail - the simplest way to eliminate the regulator or propane flow as the culprit, is to just shut off the propane valve at the tank and see if the humming stops - it's hard to know if your noise might be a humming electrical device, like a flow solenoid, or purely mechanical, like a leaking diaphram... Of course, removing all power from the propane setup by pulling the fuse is a good idea as well...
