humor, again
Cookies !!
The Christmas Scale
Superdawg
I found this site, good for hard to find auto parts
http://kalecoauto.com/index.php?main_page=index&cPath=9
Engine Scrub
$32.99
Is the inside of your motor dirty? Most likely! Some people will tell you the only way to clean your motor is to tear it down and rebuild it. This is no good!!! KaleCoAuto internals cleaner is a special combination of iron, graphite, and copper shrapnel of assorted sizes that work to sand and polish the inside of your motor! Add 2oz per quart of oil in your car. New engine clean shrapnel should be used at every oil change! Bottle includes pouring mechanism. Comes in 16oz packages. Do not ingest. Contact a physician immediately if ingested, do not induce vomiting.
Man I was really hoping they would have muffler bearing.. The parts store was stumped and even asked what color my truck was and still couldn't source anything... hahah good find
Muffler Bearing
larger image
Muffler Bearing
$33.95
Do you have an annoying rattling in your mufflers? Are they sagging a little? Don't quite sound right? That could be the symptoms of a worn muffler bearing. Allow me to introduce the KaleCoAuto muffler bearing! It's unique iron-graphite composite with pre-grease-packed assembly provides over 200,000 miles of smooth muffler operation! It is most likely they will outlast your mufflers. Also works well on heavy duty exhaust systems. One per muffler.
These are for all of the Powerstroke owners
http://kalecoauto.com/index.php?main_page=product_info&cPath=11&products_id=36
Adjustable Powerband
$95.99
Wish you had a little more low end torque? Maybe you want a high revving formula1-esque screamer? KaleCoAuto's Adjustable Powerbands are the perfect solution! The power bands are made from titanium-injected rubber, with high grade 440 fasteners. Six links are included. One band is for horsepower, and the other for torque. You may use more than three links per side, but extreme caution should be taken!
