Just had 305-70-16 ProComp AT tires installed and then balanced on a Hunter GSP9700. I've had the truck up to 75-80 and it's real smooth
I'm suprised as these are big fat heavy (45+lbs) tires.
I watched them balance tires, the machine makes it almost a no brainer for the tire tech. 3 of 4 tires only needed weights and the machine spun the wheel/tire to the exact spot and indicated which side of the rim the weight should go. Then it rechecked for balance.
On one of the tires the machine stopped and told the tech to spin the tire on the rim and even showed him exactly where to spin the tire to in relation to the rim.
Here's a link to the Hunter sight that will find the closest shop in your area, but there are some shops not listed so calling and asking may be a good idea if you don't find one close. The machine costs $8,000 so the small shops probably don't have em unless they do the big $ cars and trucks. Canepa engineering here in Santa Cruz had one because it was the only machine that would do the 18" and larger rims for the pimp mobiles.
Click on "locate a GSP9700"
http://www.hunter.com/pub/product/product.htm
