My Ram stopped blowing air out the "in your face" vents, and defaulted to the defrost and/or floor positions during last week's trip up 75 to Tennessee. It was about 15 degrees in the mountains, and the three day trip made me appreciate any heat I could salvage out the defroster. I've read that the defrost setting runs the A/C, too, which may explain why the truck didn't heat as well.
I checked for vacuum at the fittings behind the driver's side firewall in the engine compartment, and both seemed to be attached properly, and getting plenty of vacuum.
I can move the blower switch positions freely, and direct air to the floor or dash, but noplace else.
I also noticed, for the first time in its 100,000 mile history, that the truck's cruise control was "balky," and didn't want to stay where I set it. I tried performing the "retraining" (computer related) steps, and it seemed to do a little better, but the tendancy of the cruise, all of a sudden, is to want to drift upward in speed, then drift back down, and finally "hunt" its way to the setting I first selected. It's never done this before.
Curiously, once it finds the proper setting, I can hit the brakes, then hit "resume," and the truck will find and stay exactly at the correct speed without the drifting up/down problem.
I understand that cruise control "sketchiness" is often related to problems (vacuum-related) that also affect the heater vent controls, inside the cab. When I select the forward-blowing vent positions (as opposed to the defroster), I think I can hear the heat/defrost door actuator working, there's a change in defrost air pressure and sound, but no air comes out the vents. I don't think that the actuator pump which moves the heat/defrost door is the problem, but could be wrong.
I've checked all the vacuum lines that are visible along the engine compartment side of the firewall, and can't see anyting disconnected. I've also removed the three lines that I can see from their hard, plastic connectors and felt them to see if they are producing suction; the seem to be getting suction.
The one connection that was a little suspect was the line that enters the firewall behind the passenger side glovebox. This vacuum line has a plastic "L" shaped fitting, and the hose side that lead into the cabin seems very small and flimsy. I pulled it off, checked it, and was surprised to see how small the inside diameter of the hose was -- not much bigger than a "swizzle stick" you'd stir a drink with. The opening in the hose seemed to have moisture in it, but that could've been my imagination (and/or crappy eyesight).
I have not traced every vaccum hose back to its point of origin, and don't (for instance) know where the cruise control "servo" is located. Any thoughts anyone has would be much appreciated.
Thanks a lot.
Thanks a lot.
