HVACControls Panel Lights
Only 2 wheels spin
Tow Rite Modulite HD/ Tipm Protection?
It appears I have a loose bulb or bad solder joint for the HVAC control panel lights. Part of the panel is dark but I can tap on it and the dark area will light up. Sometimes just hitting a bump will cause it to fully illuminate. It appears to be a bulb near the center of the panel. If I turn the lights off and back on sometimes they will all illuminate and sometimes not, but a tap will cause them to come on. Does this sound like a bulb not making good contact or a bad solder joint?
I had some bad bulbs. They are dealer only. Make sure to get the right ones, as the dash takes 2 different styles of bulb. I would try that first.
